Activity Forums Maxon Cinema 4D c4d vector output?
  • c4d vector output?
    Posted by Alan Lacey on May 26, 2008 at 6:57 am
    Hello All,
    I’ve been to supply some of my work for web use and was wondering if there is any way of outputting in some suitable vector format.
    Any advice or informaton would be very welcome.
    Alan (London)
    Alan Lacey replied 18 years, 3 months ago 3 Members · 4 Replies
  • Nolan Scott
    May 26, 2008 at 10:12 am
    Well, try Flash (SWF) Export…
    In the Object Manager assign a FlashEx-Tag from the Tag-Menu to your object.
    (this is only needed for adding object specific parameters)
    From the Render-Menu choose FlashEx V2… and make your choices…
    (be aware that SWF might ignore certain shaders, alphas, bump-maps…etc.)
    Cheers
    Nolan
  • Alan Lacey
    May 26, 2008 at 12:33 pm
    Thanks Nolan,
    I’m running ver 9.5.2 and although the Flash tag is available in the Object manager, I can’t see any way of outputting, as there appears to be no option to output to Flash via the render menu.
    Am I missing something here.
    Thank you for your help.
    Alan
  • Randy Johnson
    May 26, 2008 at 2:03 pm
    I think in 9.o the flash output was in the Plug Ins drop down menu…
    now its not in the render settings but is in the render drop down menu.
    /randy
  • Alan Lacey
    May 26, 2008 at 4:45 pm
    Thanks Randy, yes found it.
    Alan
