Activity Forums Maxon Cinema 4D C4D to After Effects problem
  • C4D to After Effects problem
    Posted by Vipati Hitesh on January 10, 2013 at 5:33 pm
    Hello All,
    I am learning C4D R11.5 And AE CS5.5. I am doing below steps :
    1. I create a 3D model in C4D.
    2. Then I apply video as material.
    3. Animate that model.
    4. Give Compositing tag and External compositing tag to the model.
    5.Then render it and import in After Effects.
    Please see below image.
    As you can see I appllied a rose petal video as material on above model, but I need to change that video frequently. For example I have appllied “A” person’s video on that model, after some days I need to apply “B’ person’s video then “C”, then “D”.etc.
    I am trying to use special passes (Buffer Object) for this purpose, but it doesn’t work properly. Moreover,
    everytime first I have to change material in C4D then render that and import it in After Effect and again I have to render it from After Effects
    Is there anyway to make this simple and easy???
    For example I can just change that video by drag and drop in After Effects.
    Is there any plugin or any trick???
    I know this problem is happening because After Effects is not a 3D but 2.5D software. So I also want to know that is there any 3D software in which I can create 3D models and give them video effects also.
    I hope you all will able to understand what I want to ask.
    Sorry for my poor English.
    Thank you.
    Regards,
    Vipati
    Tim Vaughan replied 13 years, 8 months ago 2 Members · 1 Reply
  • Tim Vaughan
    January 10, 2013 at 8:28 pm
    Re:Vision FX has a uv map plugin which will allow u to render out a uv matte and in AE apply the video grafix/movies/whatever. Check out their site for more info as well as examples. Overall, a great and necessary plugin.
    Tim
    Apple XRAID, XServe, 2008 2×3 GHz Quad-Core MacPro, Macbook Pro, XSAN, FCP Studio (7), AVID Media Composer, Adobe Production Premium, Maxon Cinema 4d, AJA Kona 3, Flanders Scientific Monitors, Panasonic HPX250’s, Kessler Crane, Glidecam…..
    Beer fridge fully loaded.
