Activity Forums Maxon Cinema 4D c4d to after effects plugin
  • c4d to after effects plugin
    Posted by Teddy Jelster on July 1, 2009 at 3:32 pm
    Hi All,
    I’ve almost lost it entirely with searching for a plugin that apparently does exist and is free, but is nowhere to be found! Its to get across all 3d info from c4d r11 into after effects9 cs4.
    Can anyone save the day?
    Cheers, eternally grateful!
    Ted –
    Adam Trachtenberg replied 17 years, 2 months ago 3 Members · 2 Replies
  • Brian Mclean
    July 1, 2009 at 8:22 pm
    i think that is a built in feature now in c4d.
    check the render settings in c4d
  • Adam Trachtenberg
    July 2, 2009 at 2:37 pm
    The Cinema/AE plugin should be in the exchange plugins folder in your Maxon directory.
    But I don’t know what you mean by “all 3d info.” You can transfer multipass layers, cameras, lights, alpha channel, and position/rotation information (for objects with external compositing tag). You can’t actually transfer 3D objects.
