Activity Forums Maxon Cinema 4D C4d Timeline
  • C4d Timeline
    Posted by Mike on June 9, 2005 at 12:00 am
    Help Please,
    I have an animation done with the camera move. the move is just on the Z axis. I stopped it at 4 seconds. Now i need to make the animation continue to 5 seconds but at the same speed. Is there not a way to tell the camera to just keep going like you can in AE with the loopOut(“continue”) expression????
    Thanks!!!!
    Chris Smith replied 21 years, 3 months ago 3 Members · 2 Replies
  • Arndt Von koenigsmarck
    June 9, 2005 at 9:49 am
    You have to have a look at the distance the camera moved within the 4 seconds. Divide this value by 4 and add this amount to the keyframed z position of the camera. After that move the z position keyframe to second 5 in your timeline and you are done. I don’t know any easier way to do it in C4D.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Chris Smith
    June 9, 2005 at 5:15 pm
    Select your object. Go to the Fcurve tab in the timeline. Select your keyframes. In the curves menu (fcurve menus) select Cycle w/ offset to keep the curves goin in the same “direction”
    Chris Smith
    https://www.sugarfilmproduction.com
