Activity › Forums › Maxon Cinema 4D › [C4D r14] AE CC doesn’t import .AEC. How to dale it?
  • [C4D r14] AE CC doesn’t import .AEC. How to dale it?
    Posted by Duca Simone luchini on February 13, 2014 at 10:54 am
    Hello everybody,
    AE CC doesn’t import .AEC files and I don’t know how to import my Cinema 4D render passes to completely dale compositing.
    I try to use CINEWARE but I can see any single render pass… so, if you want to change Opacity or blur a single pass, you cannot make it! So, there is a way to import in AE CC in the right way as .AEC (with a correct blending mode, of course).
    Maybe there’is a plugin? or a AE import preset?
    Help please!
    Adam Trachtenberg replied 12 years, 7 months ago 3 Members · 5 Replies
  • Ronny Traufeller
    February 13, 2014 at 11:08 am
    i know that you can use open-exr layered files
    to get the right blend modes into c4d,
    maybe it alo works with other output formats,
    i am not familiar with the newer features of cinema
    with that, i think you can extract them easily using cineware,
    but gettting the blendmodes, thats something i didnt try jet.
    but would be sweet to know,
    cheers..
    ronny
    traufeller.de
  • Duca Simone luchini
    February 13, 2014 at 11:34 am
    Hi Ronny,
    unfortunately there’s no way to extract render passes from Cineware…
    I search a way to import render passes (Open EXR or .psd) with the right setted blending mode, as well.
  • Ronny Traufeller
    February 13, 2014 at 11:39 am
    mmmmh maybe you need to rebuild it by hand 🙁
    traufeller.de
    February 13, 2014 at 1:17 pm
    Achhhh,
    or maybe use AE CS6…!
  • Adam Trachtenberg
    February 13, 2014 at 5:10 pm
    Try installing the latest C4D->AE/cc plugin: https://www.maxon.net/support/updates/plugins.html
