Activity › Forums › Maxon Cinema 4D › C4D Particles Can someone please help me
  • Kouraib Abdmalek
    November 21, 2023 at 8:23 am
    Hi Naveen,
    I think that you could simulate the scene perfectly using dynamics instead of particles. I have attached a file in which I explain the principle of doing this. all you have to do is adjust the values to get a bounce that suits the scene you want to work on.
  • Naveen Ns
    November 21, 2023 at 4:16 pm
    Thanks a ton. yeah this is cool but how to make the pellets continuously grow come out from holes of the disc? without using particles
  • Kouraib Abdmalek
    November 22, 2023 at 10:12 am
    You are welcome! As for doing this continuously, you can use Cloner to repeat the action and you will not need to do this infinitely, only until the cycle ends you can make this repeated to make it appear as if it is continuing. I have attached a file that explains the idea more.
  • Naveen Ns
    November 23, 2023 at 1:15 am
    Wow thanks again. I maybe asking too much Iam totally new to C4D animation
    how to animation the cylinder height in a sequence to show they are coming out of the hole. also once the pellet fall it should grow again.
    do we have to animate it n then clone them on the wheel?
  • Kouraib Abdmalek
    November 23, 2023 at 9:32 am
    You are welcome, Naveen! I have modified the file for you to make it appear that the pellet is falling without stopping. As for making them high sequentially, I think you should use Expresso for that.
    thanks!
