Activity Forums Maxon Cinema 4D C4D noob questions: Motion Blur and GLobal Lighting
  • C4D noob questions: Motion Blur and GLobal Lighting
    Posted by Haydn Nelson on February 20, 2008 at 3:55 pm
    Hi guys
    I have created a nice flag animation from a tutorial using a plane & clothilde wrapped in a nurbs and have encountered 2 little problems:
    Motion Blur
    I would like to add some motion blur to make the animation more realistic and have tried adding a Motion blur tag to the plane and activating Objecz Motion Blur in render settings but to avail… Theres no visible blurring in the pattern or at the flag’s edges 🙁
    Any ideas what im doing wrong?
    Global Lighting
    My renders seem to be light from bottom left instead of top left – how do i change that? :S
    Thanks in advance people
    Haydn Nelson replied 18 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 20, 2008 at 9:37 pm
    As the manual explains, object motion blur only works with object translation/rotation/scale — does nothing for deformers or point-level animation. Try using vector motion blur instead.
    As far as the light goes, you can adjust the location of the default light by selecting the viewport’s display menu and >default light. But for best results you’ll want to use light objects.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Haydn Nelson
    February 21, 2008 at 8:17 am
    Thanks Adam
