Activity › Forums › Maxon Cinema 4D › C4D exporting the wrong frames
  • C4D exporting the wrong frames
    Posted by Byron Stanford on August 4, 2021 at 2:31 am
    Hey everyone, hoping you can help me with a strange and rather annoying bug I’m experiencing with C4D. I was rendering a project through the render queue and experienced a crash. No big deal, it’s redshift this stuff happens. So I reopen the project, which I had to save to add to the render queue, so I expect I can just resume my render and it should give me the missing frames. When it shows the job as completed and I go to compile my frames I noticed I’m missing a bunch of frames.
    It seems that whenever I’m setting a specific frame range to render, it’s rendering other frames. I’m attaching a screenshot here where you can see that although my frame range is set to manual, and I have set a specific From and To range, below it’s giving me a different range that it’s going to export. Is this a bug? Or has something been messed up in my file with the crash?
    Thanks in advance!
    Justin Thomson replied 5 years, 1 month ago 3 Members · 2 Replies
  • Jim Scott
    August 4, 2021 at 5:08 am
    If this is happening in every project, then I would suspect a bug. If only in this one, then I would guess that the project has gotten corrupted and you could try copying everything into a new project and setting up the render there.
  • Justin Thomson
    August 4, 2021 at 4:43 pm
    Check to see if you are using “Takes” they may be overriding your render settings
