Activity › Forums › Maxon Cinema 4D › C4D Export to Maya Normals Screwed Up Answer ASAP
  • Adam Trachtenberg
    September 20, 2018 at 4:12 pm
    Have you checked to make sure the normals are correct in C4D? You won’t see any problem unless you go into polygon mode and select all.
    What format are you using for export?
  • Ravy Studios
    September 20, 2018 at 9:30 pm
    Thanks for the fast help i already found a way to fix it inside of maya. ☺
