Activity › Forums › Maxon Cinema 4D › C4D crashed after 24+ hours of rendering, and the .mov export is corrupted. Any chances for recovery?
  • C4D crashed after 24+ hours of rendering, and the .mov export is corrupted. Any chances for recovery?
    Posted by Dave Slydell on December 13, 2015 at 4:48 pm
    My CPU must have overheated causing my computer to crash after 24+ hours of rendering a project. There is an exported .mov file but of course it won’t play (tried with VLC, Quicktime, WMP)- I’m getting a Error -2048.
    After quite a bit of googling, it appears my options are limited to buying software that will extract the visual information from the damaged .mov file and convert it to a new playable format. I thought I’d ask the cow crew to see you all know of another solution to fix this corrupted .mov file so I can at least use what has been rendered up until the crash.
    Dave Slydell replied 10 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    December 14, 2015 at 4:42 pm
    not the I know of, it doesn’t help now but the longer the render gets the more reason there is to render to an image sequence rather than a mov or avi so that in a crash situation you only lose one frame
  • Dave Slydell
    December 15, 2015 at 4:44 pm
    Lesson learned for sure. Luckily this was a project for a class and not a client…
