Activity › Forums › Maxon Cinema 4D › C4D and realflow ploblem
  • C4D and realflow ploblem
    Posted by Emmet Reddy on July 12, 2007 at 2:08 pm
    hi all i have created a text graphic called milk in C4d then i have the milk flowing over the text in realflow it looks pretty ok, but i just cant seem to get the liquid wright it looks more like ice-cream than milk i have played around with the particles in my spline, for ages buy i just can seem to get it to look like milk its too thick, does anybody know what settings to use?
    Alejandro Torres replied 19 years, 2 months ago 2 Members · 1 Reply
  • Alejandro Torres
    July 12, 2007 at 9:24 pm
    Hi, maybe you should try to lower the ext pressure and the viscosity, as well as considering major changes in the scale, perhaps what you need are more particles to cut the thick look. And if you have them you could also try to reduce the blending of the particles in the mesh as well as reducing the poly size but it will definitely increase the render times.
    Hope this helps
    Alejandro
