Activity Forums Maxon Cinema 4D C4D 10 Workshop question
  • C4D 10 Workshop question
    Posted by Randini on January 20, 2007 at 5:38 am
    Hi Arndt
    I just got your book and have a question about a technique. I’m on a mac. On page 36 you describe holding down the control key to switch from points mode to polygon mode. Nothing happens when I do that. I tried both the command and control keys. I can do it through the selection menu, but it would be much faster your way. Any advice?
    Thank
    randini
    Arndt Von koenigsmarck replied 19 years, 8 months ago 3 Members · 3 Replies
  • Ingemar Björling
    January 20, 2007 at 1:33 pm
    It works if you have polys selected and the control click on the point mode tool.
    Renderwise Ingemar Bj
  • Randini
    January 20, 2007 at 4:15 pm
    Thanks very much! It works!
    randini
  • Arndt Von koenigsmarck
    January 23, 2007 at 3:46 pm
    by switching modes with CTRL hold down, the active selection is converted to the new mode.
    If for example you have only 3 out of 4 points of a polygon selected, switching from points to polygon mode will not select that polygon. Maybe that is what happend in your case.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
