Activity Forums Canon Cameras c300 On Screen Display going to HDMI & SDI – only want it on HDMI
  • c300 On Screen Display going to HDMI & SDI – only want it on HDMI
    Posted by Ben Brodbeck on January 9, 2014 at 9:08 pm
    I have a Canon c300 with the SDI output going to a KiPro Quad. The c300 also has HDMI being fed to an Alphatron monitor. I’d like to have the c300’s on screen display visible on the Alphatron. When I go into the Video Setup menu and turn on the HD On Screen Display option the on screen displays output to both the KiPro Quad (hooked up via c300’s SDI Out port) and the Alphatron (hooked up via c300’s HDMI output).
    Is there a way to make it only output On Screen Displays to the Alphatron?
    The on screen displays when displayed on the KiPro Quad are actually being recorded onto the clips.
    Ben
    Ben Brodbeck replied 12 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
