Activity Forums Adobe Premiere Pro C100 footage Clip names not matching in Premiere pro and SD Card
  • C100 footage Clip names not matching in Premiere pro and SD Card
    Posted by Dale Roberts on June 15, 2013 at 1:09 am
    So my media is offline in my timeline… and its a massive one.
    Ive had lots of issues along the way but right now here is what is happening-
    I’m trying to get the clips back online in the usual way. BUT- The names that Premiere calls them are not the names that they are called in the actual file on the SD card… for example-
    Premiere is trying to locate a clip called- 20130517165025.mts
    When I go and find it (i have had to reimport the media as the drive needed to be reformatted) te clip names I get from the original SD card are a lot more simply named such as 00010.MTS.
    I fear I am in ‘start again’ territory now… which is not cool as its a 46 min timeline…
    Im working off a back up copy.
    I have other issues such as other files easily findable with matching names but PP says the audio is different so it cant import the file… I think I’m in alot of trouble here…
    Any suggestions?
    Many thanks
    Dale
    Dale Roberts replied 13 years, 2 months ago 2 Members · 3 Replies
  • Dale Roberts
    June 15, 2013 at 1:53 am
    An update-
    I think I originally imported the clips via the Data Import Utility which gives the clips those massive numbers so right now I am reimporting them thru that software.. Its gonna save me a lot of work I hope!
    The other ‘findable’ files are Go Pro shots and in the edit are used in a Multi Cam sequence which is referencing the C100 Camera for audio which is why there could be a problem there… Not sure what I can do about this problem outside of manually importing the clips in and manually editing it back into the multcam sequence…
    Its all theory right now but thought I would post as I’m thinking about it all…
    dale
  • Cliff Stephenson
    June 16, 2013 at 12:40 am
    Yeah, that’s the naming that the Canon Data Import Utility assigns the imported clip, which is different than how it’s stored on the card. That long number actually means something:
    20130517165025
    or
    2013/05/17 16:50:25 – So you shot that clip @ 4:50:25 pm on May 17th, 2013. It’s actually a much better name system than AVCHD starts with and gives all the clips unique naming.
  • Dale Roberts
    June 16, 2013 at 1:34 am
    wow.. ok interesting…
    Thanks Cliff…
    I solved that problem now into my crashing hard drives!!
    dale
