Activity › Forums › Adobe Premiere Pro › C:\Windows\system32\Gpu_Shader_Engine_x64.dll
Posted by David Hare on October 19, 2015 at 3:59 pmAnybody know what this means? C:\Windows\system32\Gpu_Shader_Engine_x64.dll
David Hare replied 10 years, 11 months ago 2 Members · 5 Replies -
Walter Soyka
October 19, 2015 at 6:33 pmI assume your other thread is related to this, but no one can help you unless you’re a bit more specific about what you’re seeing.
What is the exact error message you are getting?
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
David Hare
October 19, 2015 at 7:49 pmHi Cheers for the reply. Im getting the error saying Error with Gpu_Shader_Engine this is when i try to do a replace with after effects file. And im also getting a Failed to allocate sequence_data. This one only happens after ive been working for an hour or so though.
Walter Soyka
October 20, 2015 at 9:51 amThis file seems to be installed by Red Giant Software. I’d suggest making sure that your Red Giant effects are up-to-date, or maybe uninstalling and reinstalling. Also, make sure your graphic drivers are up-to-date.
Walter Soyka
David Hare
October 20, 2015 at 9:59 amI wondered if it had something to do with that. Everytime i’ve had red giant software i’ve had some sort of a problem. Ill try to uninstall then reinstall.
Cheers for the help.
