Activity Forums Adobe Premiere Pro C drive still filling up
  • C drive still filling up
    Posted by Mikkel Dalbøge on October 22, 2015 at 8:07 pm
    Hello
    I recently installed a new version of windows, and with that I installed of course Adobe Premiere Pro CC 2015 (newest version)
    I know that you need to relocate the Cache drive and Media Cache files to another drive, in order for the C drive not to fill up with conformed files/cache files. But even though I already did that, I can see that every time I open a project in premiere, my C drive is getting filled up somehow.
    “C:\Users\UserName\AppData\Roaming\Adobe\Common\Media Cache Files” is completely empty, and I can for the life of me not figure out why im still filling up my C drive?
    My conclusion is that somewhere still on my C drive files are stacking up, BUT WHERE!?!?!
    Can someone please help me?
    Best regards,
    Mikkel
    Mikkel Dalbøge replied 10 years, 10 months ago 2 Members · 4 Replies
  • Jon Doughtie
    October 23, 2015 at 4:32 pm
    The dreaded temp folder, which must be dealt with manually (unless you write a batch file for yourself) may be the issue.
    Navigate to users / (your name) / appdata / local / Adobe / temp. You may have a huge pile of temp files sitting in there, awaiting your disposal.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Mikkel Dalbøge
    October 23, 2015 at 6:46 pm
    I tried to locate that directory, but cant find it :/
    Did i mention that im on a windows 10 PC? Dont know if thats relevant?
    But once i get into the users directory, theres no folder called appdata :/
  • Jon Doughtie
    October 23, 2015 at 7:02 pm
    I’ll have to check on my Win10 machine at home. But I had an error in the path I provided anyway.
    It is actually \Users\name\AppData\Local\Temp.
    System:
    Win 7 64-bit
    32GB RAM
  • Mikkel Dalbøge
    October 24, 2015 at 3:52 am
    It turned out to be after effects that had a cache folder in there.. Just cleared 6 GB.. Thank you 😀
