Activity Forums Lighting Design Buying fluorescent lights for green screen shoots.
  • Buying fluorescent lights for green screen shoots.
    Posted by Larry Watts on January 4, 2012 at 6:06 pm
    I’ve done a half dozen green screen shoots with tungsten lights. I’ve also keyed those in editing and understand the issues.
    I want to total fluorescent with my new portable 9′ x 18′ green screen because of heat and power draw.
    I will be shooting an on camera host with a single camera, although I will be using either a Canon 5D MKII or a Canon XF305.
    I already own photoflex’s DSLR kit which has a 500 watt equiv. fluorsecent light with softbox.
    I’m concerned that if I light the talent with two 500 wat equiv fluorsecent light with softboxes there may not be enough light for the Canon XF305. with using the gain.
    How can I tell if I have enough light without testing, which I cannot do at this time.
    Any lower cost suggestions on lighting the screen with fluorescents?
    Larry
    John Fishback
    replied 14 years, 8 months ago
    2 Members · 1 Reply
  • John Fishback
    January 5, 2012 at 8:34 pm
    I’m not sure I understand your question. Are you trying to light both the talent and greenscreen with the same two instruments? Do you have a light meter?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
