Activity Forums Apple Final Cut Pro Legacy buying an imac for editing FCP
  • buying an imac for editing FCP
    Posted by Boots73 on October 20, 2005 at 2:35 am
    Hi
    I am looking to buy an Imac for cutting at home using FCP. I am doing alot of animation work which requires a large amount of rendering. I want to buy the best imac system for cutting render time down. (Why imac? I want a cheaper compact system at home and will by a g5 tower later down the line with some other editors.)
    So my question is does anybody know how different the renders speeds and preformance will be bewteen the just outdated imac 2 ghz system and the new imac 2.1 ghz system that has a new type of graphics card in it?
    Thats is compareing a imac 2 ghz system with 2 gig of ram in it
    and the new imac 2.1ghz system with the 1.5 gig of ram in it and faster graphics card (cant afford the 2.5 gig option).
    I am a little confused as to why the newer one should be faster when it has less ram in it.
    thanking you
    Kevin Monahan replied 20 years, 11 months ago 3 Members · 2 Replies
  • George Loch
    October 20, 2005 at 4:42 am
    [boots73] “I am a little confused as to why the newer one should be faster when it has less ram in it.”
    Because it’s faster ram. The data can be moved more quickly in and out of the cpu and that translates intogetting more things done per cycle.
    I would just make sure to get the 20″ and some f/w storage. The iMac will allow you to cut very well in FCP. It will just be the rendering times that suffer and the amount of RT preview you can get.
    -gl
  • Kevin Monahan
    October 20, 2005 at 7:38 pm
    You would be so much happier with a tower. You are forced to use unsupported FireWire drives with an iMac. Not good.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
