Activity Forums Adobe Encore DVD Button Question
  • Button Question
    Posted by John Ray on October 19, 2005 at 5:56 pm
    I want to create a a menu that has a graphic I created as the button which designates the active link. I set up my button folders(+) in photoshop and the layers and (=1)highlights. When I preview my menu and move the mouse over the second button the graphic appears but not as it should. What I basically see is an outline of it with the detail replaced with a solid color, which I believe is coming from the color scheme. How can I or better yet what am I doing incorrectly that is causing the graphic not to display when I move the cursor over it on the second button?
    John Ray replied 20 years, 10 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    October 20, 2005 at 4:35 pm
    You can’t do web-style rollovers like you’re describing on a DVD. When you roll over a button, the highlights are limited to three colors. Each color is defined by the content of the =1, =2, and =3 layers of the button in Encore.
    In your case, the outline you’re seeing is probably happening because Encore needs to determine what parts of your color image are bright enough to be shown.
    Much of this is explained in Dan Brown’s video on highlight colors:
    https://www.adobeevangelists.com/encore/index.html
    There is a way to work around this limitation, though it’s a little messy. Search this forum for “rollover” and you should find the old posts describing it.
  • John Ray
    October 26, 2005 at 1:57 am
    thanx tim…
