Activity › Forums › Adobe After Effects › butterfly made from light
  • butterfly made from light
    Posted by Ranjha on May 9, 2005 at 10:03 am
    Hi people,
    How would you go about creating a flickering butterfly that is made purely out of light and moves randomly around the screen. (kind of like tinkerbel from peterpan, if you know what i mean)
    regards,
    Ranjha
    Ranjha replied 21 years, 4 months ago 3 Members · 3 Replies
  • Phil
    May 9, 2005 at 2:02 pm
    i think there is tutorial out there, on making a butterfly. then just use shine, or glow to get your light butterfly. you’ll have to do something thinking on your own, but this is a start. i’ve done it, and it wasn’t that hard (if i remember correctly)
  • Steve Roberts
    May 9, 2005 at 2:07 pm
    If the butterfly is small, you might be able to get away with just a few images of wings open/closed/inbetween. Make a movie and loop on re-import.
    As for the path, try using write-on to draw the squiggly path, or animate the position smoothly, then apply a wiggle expression to make the butterfly wiggle about.
    Steve
  • Ranjha
    May 9, 2005 at 2:13 pm
    ahh ! seems quite simple now, just needed a point in the right direction, thanks!
