Activity Forums Avid Media Composer “bus error” in thread “mainthread”, at address 0x0
  • “bus error” in thread “mainthread”, at address 0x0
    Posted by Len Hugh on March 7, 2010 at 3:15 am
    I have added red files into red rushes and then created QT wrappers and an ALE.
    I have then imported the QT wrappers into AVID.
    I then select the clips and try to import the ALE. I then get an error which then crashes the avid.
    The error is
    I have taken all the external drives off my computer and still the same error.
    does anyone know how to get around this?
    OSX 10.6.2
    processor 2.16 ghz intel
    3gb ram
    MC 4.0.2
    thanks
    Len Hugh replied 16 years, 5 months ago 3 Members · 4 Replies
  • Job Ter burg
    March 7, 2010 at 10:55 am
    First things first: 4.0.2 was never qualified to run under Snow Leopard (10.6), so you’ll need to update to 4.0.4 or 4.0.5 first.
    https://www.avid.com/register/mcsoft_dl.asp#previousVersions
    And: yes, it’s a free update. 😉
  • Len Hugh
    March 8, 2010 at 11:00 am
    thanks for the link and info, I will update and see how that goes.
    cheers
  • Jonathan Ellman
    March 24, 2010 at 5:34 am
    I was sent this information by Avid customer help:
    This is a bug and has been logged for resaolution. I dont know when that will be right now but in the interim you can get around it by ALWAYS selecting the “Text” tab before the “Script” tab, and the error won’t occur. Also, if you disables AMA, the error won’t occur.
    And selecting the “Text” tab works
  • Len Hugh
    March 28, 2010 at 12:50 am
    Thanks for the info.
    I did try it on the latest update of avid and the bug was still there.
    I am a little confused about what an AMA is. do you know?
    I will try the work around and see how it goes.
    Thanks again
