Activity › Forums › VEGAS Pro › Burnng DVD in HD
  • Burnng DVD in HD
    Posted by Dan Hughart on May 24, 2010 at 11:27 pm
    I am trying to burn a DVD in the same high definition as the original video of 1920×1080 60i. So far, DVD Architect Studio 4.5 won’t give me anything better than 720, which doesn’t look anything near as good as the video I started with. I am using Vegas 8 as my editing software.
    Is is possible to burn a one hour movie on a standard DVD and get the same 1920×1080 resolution without getting into Blu-Ray discs?
    How can I get a hd DVD?
    Terry Esslinger replied 16 years, 4 months ago 3 Members · 3 Replies
  • Scott Francis
    May 25, 2010 at 12:25 am
    DVD’s are at best 720×480…that is the limit. I know of no way to burn HD video onto a DVD other than as data. There may be some other software that allows you to do this, but it would be very limited in the length of time you can put on it. I am not sure if Nero allows you to do this, older versions did allow you to put DVD video files onto a CD…but I am not sure. To get Bluray quality you need Bluray. Or what I will often do is use another codec like WMV and use their HD format…if the DVD player allows you to play WMV you may be in luck!
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • Dan Hughart
    May 25, 2010 at 12:28 am
    Thank you. I will give it a try.
  • Terry Esslinger
    May 25, 2010 at 5:15 pm
    Dan,
    Take a look at this thread. It may be just what you want!
    https://forums.creativecow.net/readpost/24/886447
