Activity › Forums › Adobe Premiere Pro › burning with premiere
  • burning with premiere
    Posted by Sylvain Desjardins on August 24, 2007 at 2:52 pm
    i guys when i burn from premiere i always get some sort of scarterd image as if it was a very little slow motion effect!
    Should i render before burnning or change quality setting when i burn? Does ram effect burning quality?
    regards, Sly
    Sylvain Desjardins replied 19 years, 1 month ago 2 Members · 5 Replies
  • Blast1
    August 24, 2007 at 5:52 pm
    What kind of source files are you using?
  • Sylvain Desjardins
    August 24, 2007 at 6:09 pm
    All my files are avi!
    August 24, 2007 at 6:19 pm
    Actualy i should tell you more because some of the material is already on a dvd as a VOB or directely from the camera. Then i punp them in Nero vision to export all of it in avi. Then i do the rest in premiere.
    Regards,Sly
  • Blast1
    August 25, 2007 at 2:08 am
    Nero Vision exports mpeg2, so in essense you are taking highly compressed video, recompressing it and then again when you export from Ppro, what you need to do is convert the original footage to DVavi, edit, then export to DVD or mpeg2 for DVD
    August 25, 2007 at 3:02 am
    Thanks for your time, i’ll give that a try and i’ll get back to you.
    Regards,
