Burning to Bluray Directly through Vegas 12
Posted by Debbie King on December 2, 2014 at 2:24 pmHello Everyone:
I am having an issue with burning my project to Bluray. When I select the appropriate options, it asks me to insert the Bluray disc. Once I insert the disc, it tells me to insert a writable disc. It does not read my disc as writable. I am inserting the BD -R Recordable Disc. When I searched the internet for writable, I only found rewritable. Also, BD -R comes up as well.
If anyone can help me with this, it would be greatly appreciated.
Many thanks,
Debbie
PS: I am using an ASUS that comes with a Bluray burner.
Nigel O’neill replied 11 years, 9 months ago 7 Members · 28 Replies -
Steve Rhoden
December 2, 2014 at 6:18 pmSure something isn’t wrong with those discs instead?
Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Debbie King
December 2, 2014 at 6:28 pmHi Steve:
Not exactly sure. They are brand new. I just purchased them. I am trying something else to see if it is the disc. I am currently rendering the project for Blu Ray, then I am going to attempt to burn it on the blu ray disc. For some reason, Sony is not picking up that the disc is writable. When I look on my hard drive, it reads that the disc is a BD – R, so it is reading ok everywhere other than Sony.
Many thanks,
Debbie
Mark Thompson
December 2, 2014 at 7:54 pmHi,
just a suggestion, are you sure your disk supports writing? On my computer the Blu-ray drive can only read, so I had to go and get an external Blu-Ray writer. I have a Samsung Portable BD Writer model SE-506. I’m sure plenty of other vendors work as well. I use BD-RE disks, you can use these multiple times until you get a good disk.Once you do a burn play the disk on a device that you would use to play it – i.e. not your computer. I forecast that in the future you will find that the sound level is too low 🙂
mark
Bob Peterson
December 2, 2014 at 8:11 pmI have not tried a BD disk yet, but, when I insert a blank DVD, Windows always puts up a screen asking what I want to do with the disk. I always shut down that dialogue by clicking the X button to prevent Windows from doing anything to “prepare” the disk.
Debbie King
December 2, 2014 at 8:52 pmHi Mark:
I have the Asus Desktop which has a Bluray burner. I haven’t learned how to use it yet, but I do have Nero Video that I am trying to use currently to burn the file to Bluray. No success yet.
Many thanks,
Debbie
Debbie King
December 2, 2014 at 8:54 pmHi Bob:
I have seen that prompt yet. Maybe, because I put in a Bluray disc. Not sure. Right now, I’ve given up on using my computer’s Bluray burner, and am using Nero Video. I imported the video to Nero, and it’s playing video and now sound. New challenge.
Many thanks,
Debbie
Debbie King
December 3, 2014 at 12:54 amHi Mark:
Mark, do you render audio separately as well?
Many thanks,
Debbie
Mark Thompson
December 3, 2014 at 5:37 pmHi,
what’s the state of play? are you burning Blu-ray yet?For DVDA I always render sound and video separately.
When just Vegas “Burn Bu-ray” does it you it seems to render sound and vision separately but it does it all for you.
mark
Debbie King
December 3, 2014 at 6:09 pmHi Mark:
I have not been able to render Blu ray as of yet. I rendered the blu ray settings and am trying out DVD Architect. Architect is not picking up that I have a Blu ray disc; it keeps reading that it is a regular disc and there is not enough memory to burn it. I tried to burn last night, and it took almost an hour, then nothing was on the Blu Ray disc. I don’t know what it was doing.
As far as Sony, it keeps asking me for a writable disc. I’m wondering if it means rewritable. As mentioned I am using BD -R.
Many thanks,
Debbie
Mark Thompson
December 3, 2014 at 6:47 pmHi,
I just did a Blu-ray burn on Vegas 13 and (apart from the sound) it works just fine. I’m using Verbatim BD-RE 25gb 2x speed (Hard Coat).I know you have Vegas 12 but I’m sure it worked just the same.Perhaps you are trying to burn a Blu-ray that is too new for your burner? How old is your machine?
On my pc I have a BD-ROM drive and a BD-RE drive. It is easy to select the wrong one (if you also have multiple drives).
Can you do a device properties on the drive and report back on what you find?
mark
