Activity Forums VEGAS Pro burning long movie
  • burning long movie
    Posted by Werneroz on September 2, 2007 at 10:03 am
    If I burn a DVD from Architect (4.5), and the movie might be more than the DVD can take, do I select where to “split” the movie, or will I be prompted by Architect to indicate where about the first DVD will be full? Also, if I need to split, do I use the second part as a “new movie”, or how do I proceed from first to second DVD. Thanks in advance, Werner
    Werneroz replied 19 years ago 2 Members · 2 Replies
  • Edward Troxel
    September 2, 2007 at 6:41 pm
    If it’s too big to fit on the disc, it will shrink it enough to fit on the disc (requiring another recompression and reducing quality).
    If you want it to be on two discs, you need to create what is necessary for each disc separately. In other words, YOU figure out the split point, render the first section to make the first DVD and then render the second section for the second DVD and both DVDs are made separately by you.
    Edward Troxel
    JETDV Scripts
  • Werneroz
    September 2, 2007 at 11:25 pm
    Thanks Edward.
