Activity Forums VEGAS Pro Burning in Archtect 4.5
  • Burning in Archtect 4.5
    Posted by Tim Siggs on January 5, 2009 at 10:33 am
    Hi ,I am a new user of Architect 4.5.I am experiencing an ongoing problem in regard to getting a 16:9 burnt DVD displaying correctly on my new widescreen Tv.Ie it shows as letterbox display.I have recorded in 16:9,set the Vegus settings to Pal widescreen,Rendered in Pal Widescreen(I believe sucessfully).I can playback throught the computer ,say through Media player in Widescreen.I have also set my Architect settings to Pal Widescreen.However,the Tv will only play it with letterbox viewing.I would really appreciated any help as I’ve puzzled over this one for days!!Thanks,Tim.
    John Rofrano replied 17 years, 8 months ago 2 Members · 6 Replies
  • John Rofrano
    January 5, 2009 at 3:36 pm
    Check the settings on your DVD player and make sure it knows that it’s feeding a 16:9 TV. Most DVD players default to 4:3 unless told otherwise.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tim Siggs
    January 6, 2009 at 11:33 am
    Thanks John.I have looked at both of my Panosonic DVD Players and it seems that they do not have a specific setting for 16:9 but seem to rely on the TV for the Aspect Ratio setting.The Ironic thing is that I have played some old DVD’S Burnt in 4:3 Ratio and the TV will play them in 16:9 (or at least close enough to fill the widescreen).I’m at a standstill with this one but welcome any further thoughts,thanks again,Tim.
  • Tim Siggs
    January 9, 2009 at 11:02 am
    I am still battling this issue with not being able to play my burnt DVD’S on my new widescreen TV in 16:9.
    I have set all the settings in Vegas to Widescreen,also settings in both Render and Burn to Widescreen.
    I end up with the Dvd Playing with a complete black frame,which is 14:9,but when set to play 16:9,it is letterboxed and stretched.Can anyone help me??
  • John Rofrano
    January 9, 2009 at 2:35 pm
    Do store bought widescreen DVD’s play back in widescreen?
    ~jr
  • Tim Siggs
    January 10, 2009 at 10:34 am
    John,I have my tail between my legs as the solution was indeed the DVD Player.I had to delve into the menu somewhat but found that I had to change the setting to 16:9.A big thankyou to you and the team.Tim.
  • John Rofrano
    January 10, 2009 at 4:21 pm
    Most people don’t realize this as the settings are often buried deep in the setup menu. Glad you got it working.
    ~jr
