Activity › Forums › Adobe After Effects › Burning Fuse Effect in After Effects.
  • Burning Fuse Effect in After Effects.
    Posted by Phill Naylor on February 25, 2013 at 8:26 pm
    Hi Everyone,
    Looks like this might be a pretty popular question. The older posts I’ve found had broken links.
    I need to create a Mission Impossible “like” Burning Fuse and I just bought After Effects CS6. Can anyone point me in the direction of a tutorial showing how to create something like this.
    Total Newbie to After effects so be nice 🙂
    Any info would be much appreciated.
    Vishesh Arora replied 13 years, 7 months ago 4 Members · 3 Replies
  • Chris Brett
    February 25, 2013 at 9:42 pm
    – depends how realistic it needs to be / what look you want.
    If you want it to look very real suggest you shoot a real-life firework fuse or similar and key it on / add a bit of glow what ever..
    — but you might want a different sort of look and suggest a particle generator will do the trick though cant offer anyting much more than that as I wouls just get on it and play till I got something ie dont have a previous job I can supply actual info from …
    ———– anyway — god luck — just dont forget the ‘real-life’ option if it is the look you want …
    …………………. chris
  • John Cuevas
    February 25, 2013 at 11:54 pm
    Trapcode Particular has some pretty good presets that you could use as a fuse. It’s a “3D” effect, in that it respects AE’s 3D space, so it’s pretty flexible to what you may need.
    It has a trial download, so take a look.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Vishesh Arora
    February 26, 2013 at 11:53 am
    Phill
    Particular is a vast plugin, So I would suggest you to learn the basics first.
    Trapcode Particular Basics
    Once you understand the plugin properly you can go on creating the Desired Effect.
    There is a new Preset for Particular “Sparkler” which may help you to create the fuse.
    Check the tutorial:
    Trapcode Particular Sparkler Preset
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
