Activity Forums VEGAS Pro burning file with 5.1 audio in DVDA
  • burning file with 5.1 audio in DVDA
    Posted by Zack Armatt on July 9, 2008 at 8:46 am
    I’m trying to burn to dvd a movie file that has audio with 6 channels (dolby ac3,5.1). According to gspot, I have 3 compatible audio codecs installed to view this file. Rightly so cos my windows media player plays it just fine.
    Now when i try to click on this file via the explorer in DVDA, i got the hated ‘audio stream attributes could not be determined’.
    Cleverly I thought I could convert the audio file to something compatible to DVDA. Magic converter converts it to 5.1 but the audio was stretch by about 30% of the running time.
    So tell me how can I achieve what I set out to do? I just wanna burn into dvd a 5.1 surround movie and get to enjoy the surround on my home theatre system. Any help is superly greatly appreciated. thks.
    Zack Armatt replied 18 years, 2 months ago 4 Members · 13 Replies
  • 13 Replies
  • John Rofrano
    July 9, 2008 at 11:45 am
    Obviously DVD Architect doesn’t like something about that AC3 file. You were on the right path to convert the audio. I would do it in Vegas using the AC3 5.1 Surround template. This way you will be sure that it is encoded correctly for DVD Architect. You may have to figure a way to get it into Vegas first like converting it into 6 wav files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Zack Armatt
    July 9, 2008 at 12:23 pm
    John,
    Thks for the response.
    Getting into vegas is THE problem too. Apparently the file is not Sony friendly. I can easily convert it to mp3 stereo using Magic and bring it to vegas or dvda.But that will defeat the whole purpose as I would lose the 5.1 surround. if I understand this correctly 6 channels mean 6 audio files. So how do i break it into 6 different wav files? Any software that can do this? hopefully free.
  • Steve Rhoden
    July 9, 2008 at 1:10 pm
    Do yo possess Sony Soundforge ?
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
  • Zack Armatt
    July 9, 2008 at 1:31 pm
    Steve,
    Yes I do. I’ve installed soundforge 9.0.
    I’m not familiar with soundforge but I tried opening the file with it and was not successful. It doesn’t recognize the said file. It indicated no audio. But video is ok. Any other solutions? pls…
  • John Rofrano
    July 9, 2008 at 3:04 pm
    So… where did this file with the mysterious AC3 come from?
    ~jr
  • Zack Armatt
    July 9, 2008 at 5:44 pm
    Its a d/loaded file. Below are the audio specs: (as defined by Magic Converter)
    Audio #0
    Codec : AC3
    Info : Dolby AC3
    PlayTime : 1h 33mn
    Bit rate : 448 Kbps
    Bit rate mode : CBR
    Channel(s) : 6 / 6 channels
    Sampling rate : 48 KHz
    Delay : 0
    Video0 delay : 0
    ChannelPositions : Front: L C R, Rear: L R, Subwoofer
  • John Rofrano
    July 9, 2008 at 6:53 pm
    Hmmm… ok so it’s basically an “unknown” source. You can try to convert the AC3 file to a multi-channel WAV file using a tool like AC3Tool. If you do use AC3Tool, go to the AC3 > WAV tab and set the Downmix mode to 3/2 “5.1” then press the AC3 > Wav button at the bottom right.
    This will create a single WAV file with 6 channels. Just drop this file into a 5.1 Surround project in Vegas and it will lay out the 6 tracks. Then you must manually pan the tracks to LF,RF,LR,RR,C,& LFE. Finally render as AC3 5.1 Surround and DVD Architect should be happy with the file.
    ~jr
  • Steve Rhoden
    July 9, 2008 at 11:55 pm
    Yes John, that’s a handy little tool for ac3 formats that are
    a bit stubborn.
    That should prove helpful to Zack.
    Steve Rhoden
    Creative Director
  • Zack Armatt
    July 10, 2008 at 10:01 am
    John,
    I tried to do exactly what you said. But the ac3 is actually in the said movie.avi file. So, how do i extract the ac3 in the first place? Cos under the tab ac3 analysis, it only recognizes ac3 files.
    My audio is in an avi file. How??? pls enlighten….
  • John Rofrano
    July 10, 2008 at 12:57 pm
    You need to find an AVI demuxer to split the streams.
    ~jr
