Activity Forums VEGAS Pro Burning a DVD on Architect with HD material…
  • Burning a DVD on Architect with HD material…
    Posted by Charles Martin on October 12, 2010 at 1:50 pm
    I have HD 1920x 1080 material that I want to burn onto a non-HD DVD using DVD architect.
    When doing the edit should i edit in 1920x1080i project? Or would it be better to edit in a pal dv 720×576 project.
    I ask this because when you render using the Main concept and DVD template it is using the 720×576 settings.
    I actually did a test editing and rendering in 730×576 (pal) and burned a DVD using architect and it looked very good.
    Just wondering if it would make any difference editing in HD?
    Charles Martin replied 15 years, 10 months ago 2 Members · 2 Replies
  • Davd Keator
    October 14, 2010 at 6:14 am
    Makes no diference… Just keep all pre-rendered sequences in highest bit rate and resolution as possible: 1920×1080…. Let DVD arch. Conform to pal…seems best with my experience… I use cineform for everything, raw camera file to neo4k to DVD arch…fast smooth, beautiful.
  • Charles Martin
    October 14, 2010 at 11:59 am
    thanks…!
