Activity Forums VEGAS Pro Burning a Blu-Ray Disc for Viewing in Any Blu-Ray Player
  • Burning a Blu-Ray Disc for Viewing in Any Blu-Ray Player
    Posted by Terry Fein on October 14, 2014 at 9:24 pm
    I have some travel videos and slide shows I created and rendered as MP4 files for internet viewing. I now want to burn a Blu-Ray disc that will play in just about any recent Blu-Ray player. In the past, I have simply burned the MP4 files onto a Blu-Ray disc using CDBurnerXP. They have worked fine on my Sony Blu-Ray player, but not everyone has been able to play them.
    I now want to render the videos and slide shows as “proper” Blu-Ray files and burn them to Blu-Ray. Could someone point me to an easy to follow, step-by-step procedure for doing so without much fuss?
    I have a lot of experience with Vegas Pro, but virtually none with DVD Architect. Thanks.
    John Rofrano replied 11 years, 10 months ago 4 Members · 12 Replies
  • 12 Replies
  • Stephen Mann
    October 15, 2014 at 3:10 am
    Unfortunately, that’s the way it is. I’ll bet the ones that won’t play BD-r discs are a few years old.
    We had a similar problem with DVD’s years ago. The DVD players that were made before recordable DVD’s were common would not play recordable DVD’s. The first-gen BD players were made before BD-R was even out of the lab.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    October 15, 2014 at 11:59 am
    [Terry Fein] “Could someone point me to an easy to follow, step-by-step procedure for doing so without much fuss? “
    Nothing formal but how about this:
    • Open DVD Architect.
    • Select a Theme that you like or just use the Blue background.
    • Drag and drop your files onto the menu (they will make buttons by default)
    • Change the title to something sensible
    • Press the Burn button
    That should get you started.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Terry Fein
    October 15, 2014 at 4:49 pm
    Great. Thanks!
  • John Rofrano
    October 15, 2014 at 11:13 pm
    You’re welcome. Feel free to ask more questions as you go through it but that should get you started.
    ~jr
  • Terry Fein
    October 16, 2014 at 4:14 pm
    Thanks, John. Your advice is always very helpful and truly appreciated. I have gotten through the basic steps successfully, but now I have two issues to address. Let me preface this by saying that I added markers at the beginning of each video or slide show project and typed in a name. (I did so by using the “M” keystroke. I assume that is how chapter markers are created.) I then rendered several videos and slide shows as a test using Main Concept AVC for the video and checked the box to include the chapter markers in the rendered file.
    The issues I have after running the videos and slide shows throuh DVD Architect are as follows:
    1. After a video or slide show plays, it reverts to the menu. I instead want it to move directly on to the next video or slide show and start playing automatically).
    2. I am unable to click forward or backward through the videos or slideshows (if people want to just go on to the next video or slide show or skim through them quickly, like chapters in the movie).
  • Terry Fein
    October 16, 2014 at 10:45 pm
    Okay, I have figured out how to go directly to the next video/slide show rather than back to the menu (by using the link command), but I still can’t get the forward and back remote commands to work. I even tried inserting chapter markers directly into DVD Architect at the beginning of each video/slide show.
  • Pete Baratta
    October 19, 2014 at 10:14 am
    Hi guys, slightly off target but I sent out some videos (Blu-rays) that I made here in Pal land to relatives in the states…1080, 50i at 25fps. They couldn’t play them on their newish Blu ray players so I had to re-burn, re-formatting at NTSC frame rates & that worked.
    Thought the old Pal vs NTSC was not needed for HDV.
    Pete.
  • John Rofrano
    October 19, 2014 at 2:20 pm
    [Terry Fein] “Okay, I have figured out how to go directly to the next video/slide show rather than back to the menu (by using the link command),”
    Hopefully by “link” you mean that you are setting the End Action of the first video to point to the next video. The End Action defaults to Return to Menu.
    [Terry Fein] “…but I still can’t get the forward and back remote commands to work. I even tried inserting chapter markers directly into DVD Architect at the beginning of each video/slide show.”
    If you set the End Actions correctly, you should be able to use the Next Chapter button to advance the video. Note: the Previous Chapter button will not work because you can’t jump backwards across files, only forward.
    ~jr
  • Terry Fein
    October 19, 2014 at 2:24 pm
    That is exactly what I did, and once a video plays, it will automatically move to the next video. However, the “next” command on the remote control doesn’t work.
  • John Rofrano
    October 21, 2014 at 4:44 am
    Have you tried a different DVD player? Sometimes disks work on one and not another.
    ~jr
