Activity › Forums › Adobe Encore DVD › Burned movie with Encore is jumpy…
  • Burned movie with Encore is jumpy…
    Posted by Esther Casas on October 8, 2012 at 4:57 pm
    Hello everybody!!
    I am trying to burn a film into a DVD..but I have this jumpy weird issue. I see it jumping already in the preview window..
    These are the settings I have for the quicktime I am importing into Encore timeline:
    From final cut Pro I exported an Apple Pro Res 422 2048×1156 size
    @24fps 16:9 ratio.
    Import into Encore, where setting are:
    NTSC Project
    codec: MPEG-2 dimensions 720X480 rate 29.97
    do I have to export form final cut differently?? i thought i never had to do match the QT settings with the encore ones…?
    Also, in the “edit quality Presets” window , do I have to change some export settings? As an option there is Format MPEG2-DVD and then also gives you size options, is mine NTSC SD MPEG-2 High quality? I am assuming I have to choose the same setting as I chose in the project settings?
    i KNOW MY SOURCE IS 24FPS, BUT THAT IS NOT A PROBLEM WHEN BURNING A 29.97 ntsc, RIGHT? i NEVER HAD A PROBLEM BEFORE WITH THIS…
    Esther Casas replied 13 years, 11 months ago 2 Members · 2 Replies
  • Daniel Ludwig
    October 13, 2012 at 8:48 am
    Esther,
    if you have 24fps souce, you should create a preset in compressor to encode your assets.
    24fps-source will be transcoded to 29.98 NDF (non dropped frames) with 3:2 pulldown, but you need to slow it down to 23.98 first. this could be done using apple cinema tools – very easy, one click.
    and for better results you should do scaling to NTSC frame-size before encoding.
    cheers
    danny
    PS:
  • Esther Casas
    October 13, 2012 at 4:51 pm
    I will do! thank so much Daniel!!
