Activity Forums Adobe Encore DVD burned DVD stops and wont auto run
  • burned DVD stops and wont auto run
    Posted by Declan Power on June 12, 2014 at 10:40 am
    this the simplest project ever, and i have years and years experience in encore,
    one timeline to auto play.
    mpeg file was rendered from vegas 10 pro..
    rendered with dvd architect export settings.
    that is the only difference from what i normally do.
    (i will be using vegas for allot more projects so i need to get dvd’s burning quicly and effiecently , to get into a quick workflow.
    in addition i have just installed cs6,
    region settings changed to 8 – international
    etc etc,
    i have also tried to encode in dvd architect 5.2 ,
    exactly the same problem,
    dvd plays on a pc , with dvd software player installed, no problem,
    its just the standalone dvd players that wont play the disc.
    i have tried everything at this stage,
    could someone please help,
    dec
    D.Power
    EG Digital Productions.
    44 28 677 42828
    d.power@emerging-group.com
    Declan Power replied 12 years, 3 months ago 3 Members · 3 Replies
  • Bill Stephan
    June 12, 2014 at 4:59 pm
    Region 8 is only for the DVD players installed on passenger aircraft. Depending on what part of the world you are in, you want regions 1-6. You can make a DVD with all regions enabled unless your customer requires that the disc is restricted to one region.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Jeff Pulera
    June 12, 2014 at 7:24 pm
    Like Bill said, don’t mess with Regions unless you have a specific need, the default ought to be “All” and just let it be then
    Jeff Pulera
    Safe Harbor Computers
  • Declan Power
    June 13, 2014 at 8:36 am
    checked out the regions and tested, this is nothing to do with my problem.any other ideas ?
    D.Power
    44 28 677 42828
