Activity › Forums › DVD Authoring › Burn dvd with dual audio with menu option
Posted by Varun Saxena on August 25, 2018 at 4:20 pmI have few 720p MKV movies which has dual audio (English and HINDI) which I want both audio on the DVD when converted, is it possible? If so how would the user switch audioON DVD MENU?…THNX…
I WORK ON PC & MAC BOTH
Alexander Kallas replied 8 years, 1 month ago 4 Members · 5 Replies -
Alexander Kallas
August 26, 2018 at 12:50 amDo you want to make a data DVD or a playable DVD, for the later you will need to make an m2v file first.
Cheers
Alexander -
Varun Saxena
August 26, 2018 at 4:29 pmhi
i want to make a playable DVD with dual layer and i want a option to switch language in menu bar on dvd
Mark Landman
August 26, 2018 at 7:07 pmYou can do it in DVD Studio Pro on a Mac. Put multiple audio tracks on the disc and use a menu to select which one to play. DVDSP was EOL’ed some time ago, so I don’t think it will run on the last few versions of the MacOS. I keep a disc with Mountain Lion for running it on.
I’m sure there are multiple programs on the PC side that will do what you need, but since I don’t run Windows I can’t speak to the specifics.Mark Landman
PM Productions
Champaign, IL -
Jeff Pulera
August 27, 2018 at 9:23 pmI’ve used dual-audio tracks on a DVD created with Adobe Encore. Not sure if you can select audio from menu though, without having two copies of the video as well then.
The DVD player remote control will allow the user to select different audio on the DVD (if it exists) without using any menu on the DVD itself. So in Encore, I just used two separate audio tracks on the same Encore timeline, and then user is able to select secondary audio with their DVD player box remote. I only did this once, and it was several years ago.
The first thing is to be able to separate the English and Hindi audio tracks as individual audio files out of the .mkv source. There are a lot of freeware/shareware programs for PC that do that sort of thing. Perhaps “demuxing” software.
I use Adobe Premiere to edit. Using that, I would export the video clip as MPEG-2 DVD format, which is an .m2v file. Encore prefers audio as a separate file, so in your case two separate .wav files, one for each language. Then add the 3 clips to the Encore timeline (video, audio 1, and audio 2 tracks).
Not sure what software you might have access to, other packages may work differently.
Jeff Pulera
Safe Harbor Computers -
Alexander Kallas
August 27, 2018 at 10:47 pmEasy in DVDSP using “stories”. Make the menu point to the different story which includes the different language.
Cheers
Alexander
