Activity Forums Apple Final Cut Pro Legacy burn a SD DVD out of HD footage
  • burn a SD DVD out of HD footage
    Posted by Aris Gharibain on May 20, 2009 at 5:30 pm
    Does anybody know what’s the best way to burn a SD single layer DVD out of HD footage (1920×1080)? I just burned a SD DVD with DVD studio pro, but the quality looks worse than DV. Do I need to have any kind of card in my computer?
    Peace,
    Ari
    Viktor Kibanov replied 17 years, 3 months ago 3 Members · 6 Replies
  • Shane Ross
    May 20, 2009 at 5:32 pm
    Nope. Export a self contained file, take that into Compressor and use the BEST settings for DVD, that match your timing, then take the result into DVD SP.
    Shane
  • Aris Gharibain
    May 20, 2009 at 5:50 pm
    I matched the timing of the Q-T with the compressor bit rate, then I took the MPEG2 to DVD SP. DVD SP failed, and gave me error message says: video bitrate is high. Also, the quality looks worse than DV footage.
    Ari
  • Shane Ross
    May 20, 2009 at 5:57 pm
    SO you took the QT file into Compressor, just dragged the DVD setting that you wanted onto that…DIDN’T CHANGE ANYTHING…clicked SUBMIT, then took the final result into DVD SP and it didn’t work?
    I do this all the time. With ProRes footage. Looks fine. Not on a HDTV, it looks like crap there. But that is because it is taking an SD DVD and playing it on a NON-upconverting DVD player to an HDTV. Icky.
    Shane
  • Aris Gharibain
    May 20, 2009 at 6:09 pm
    I choose best dvd, two pass VBR and change the bit rate to the highest in the compressor. Then I took the MPEG2 to DVD SP.
    So, I can’t do anything about the quality unless I burn the footage on a bluray, right.
    Ari
  • Shane Ross
    May 20, 2009 at 6:20 pm
    [Aris gharibain] “and change the bit rate to the highest in the compressor.”
    Don’t do that. Do not change anything. You are changing the bit rate to something DVD players cannot play. Choose the preset, and leave it alone.
    Shane
  • Viktor Kibanov
    May 20, 2009 at 9:57 pm
    I´m not professional and don´t have AJA, Kona, Matrox to do downconversion, so I used these recommendations with very good quality: https://www.kenstone.net/fcp_homepage/hdv_timeline_to_sd_dvd.html
    Now I use other options: the fast way – timeline to DV/DVCPRO NTSC (if your footage is NTSC, if not – DV PAL, but I didn´t check it) with QT conversion and then Compressor DVD MPEG 2 highest quality; the other way – timeline to 1080HDV30p with QT conversion (progressive) and then – Compressor DVD MPEG 2 highest quality – with slightly better result.
