Activity Forums VEGAS Pro Bump Map Help
  • Bump Map Help
    Posted by Carson Young on April 11, 2009 at 9:53 pm
    My Alzheimer’s must be kicking in, because i’ve accomplished this effect before, but anyway. I’m trying to get a text ripple effect, with a water ripple video clip I have, using the Bump Map, but am doing something wrong. Can anyone help?
    Thanx for reading,
    Carson
    John Rofrano replied 17 years, 4 months ago 2 Members · 3 Replies
  • John Rofrano
    April 11, 2009 at 10:45 pm
    Hi Carson,
    Actually the Bump Map is your problem. You want to use a Height Map to make the text conform to the height of the waves. You need three tracks to do this. The first (top) track is the height map material. In your case it would be the water. The second (middle) track is the Text and the third (bottom) track is the water again. Change the composite mode of the top track to Custom… Height Map. Change the text track to be a Compositing Child of the top track and ten just adjust the amount of amplitude with the Height Map FX.
    Your timeline should look something like this:
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Carson Young
    April 11, 2009 at 11:27 pm
    AH..HA! Height Map. It’s all coming back now. I really appreciate it John, thanks a ton for your time!
    Carson
  • John Rofrano
    April 15, 2009 at 3:52 am
    You’re welcome… glad I could help.
    ~jr
