Bump map
Posted by Roger Bansemer on September 11, 2010 at 7:18 pmI once saw a tutorial on how to make text have a water ripple effect as a video rolled beneath it. For instance a pebble is tossed in the water and the text ripples with the movement.
I think it had something to do with the bump map but I’m not sure. Anyone help me find that tutorial or give some suggestions.
Thanks.Roger Bansemer replied 16 years ago 3 Members · 5 Replies -
John Rofrano
September 11, 2010 at 9:13 pmYou want to use either the Displacement Map or the Height map (not the Bump Map). All you need is two tracks:
- Place your regular video or title, etc. on the bottom track.
- Place the video or generated media that is going to cause the ripple on the top track.
- Then change the Track Composite Mode of the top track to Custom and select Displacement Map.
- Finally, make the second track a compositing child of the first. This will get rid of any edges introduced by the displacement wrapping
The bottom track will now be displaced by the top track. Try it with the Height Map as well because that gives you more control over how much the height affects the distortion.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Roger Bansemer
September 12, 2010 at 12:49 amThanks for this tip John. This is one I didn’t know. However, I was looking for the effect where the text looked as if it were floating on the water and as a wave went by (or any object) the text would wrap over it as if the text were floating on top of the wave.
This is not a wave circle but rather the look of text floating on top of a wave (if water is what the video clip is) -
John Rofrano
September 12, 2010 at 4:59 pmThis is not a wave circle but rather the look of text floating on top of a wave (if water is what the video clip is)
I’ve created a tutorial on YouTube called “ Floating Text on Water in a 3D Perspective with Sony Vegas Pro” to show you how to do this. Be sure to watch it in HD:
Hope this helps,~jr
http://www.vasst.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Roger Bansemer
September 12, 2010 at 5:39 pmWow! That was great. That’s exactly what I was trying to learn plus you’ve given us more tweaks that are really helpful. This is a great tutorial.
Thanks John.
