Activity Forums Adobe After Effects bullet time
  • bullet time
    Posted by Cyprusx on October 16, 2007 at 6:33 am
    hi
    to create a bullet time effect i cut an image out of a bullet and have it leaving the barrel in slow mo, but the bullet looks pretty flat, is there a way i can make it look more real
    Steve Roberts replied 18 years, 10 months ago 2 Members · 3 Replies
  • Steve Roberts
    October 16, 2007 at 10:48 am
    You need to make a 3D bullet. Learn to use a 3D application or buy Zaxwerks Invigorator.
  • Cyprusx
    October 17, 2007 at 7:16 am
    is there a way i can make it look more real in AE, for example ligting
  • Steve Roberts
    October 17, 2007 at 2:23 pm
    If the bullet is moving, its perspective will change. Its shape will change. For that you’ll need a 3D bullet in a 3D application, or Zaxwerks.
    Right now, you have a flat picture of a bullet. Lighting in AE won’t change its shape or give it a third dimension. We all have to accept that AE works with flat planes floating in space.
