Activity Forums Apple Final Cut Pro Legacy Bulk Changing Angle Info
  • Bulk Changing Angle Info
    Posted by Paul Lowey on August 29, 2009 at 4:26 pm
    I’m multiclip editing a huge project that involves many cameras with TC synced – and each camera has created about 50 or so clips. In order to multiclip edit I need to assign each clip an angle – and it’s a little redundant to click on each clip and enter the angle information individually. Is there a faster way of doing this? Some way of doing a “Change All” or something like that?
    Thank you for your help!
    Andreas Kiel replied 17 years ago 2 Members · 1 Reply
  • Andreas Kiel
    August 29, 2009 at 11:17 pm
    Yes there is.
    In the browser view scroll to the Angle column or make it visible by crtl-click one of the table column titles.
    Enter an angle 1,2,3… for any single clip which needs an angle – if needed. Select all the the clips you want to assign an angle to and crtl-click the angle entry of any of those. From the popup select the angle. That’s it.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
