Building peaks crashes Sony Vegas 12
Importing an AVI video was a problem until I installed Xvid. Now when I drag and drop the AVI into the time line area, the audio track says “building peaks” then Sony Vegas crashes. I’m not a techno guru by any means. It is probably a codec that’s causing the issue but am unsure which one it is and where I can download it.
Here is the Media Info:
General
Complete name : F:DerekUFORecordings30 Nov 2013Original Raw FootageMPEG0001.AVI
Format : AVI
Format/Info : Audio Video Interleave
File size : 1.40 GiB
Duration : 30mn 0s
Overall bit rate : 6 672 KbpsVideo
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 30mn 0s
Bit rate : 6 576 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.714
Stream size : 1.38 GiB (99%)
Writing library : ZoranAudio
Format : ADPCM
Codec ID : 2
Duration : 30mn 0s
Bit rate mode : Constant
Bit rate : 88.2 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Bit depth : 4 bits
Stream size : 19.0 MiB (1%)
Interleave, duration : 92 ms (2.77 video frames)
