Activity Forums Adobe Encore DVD Building image
  • Building image
    Posted by Salvazalvi on June 15, 2005 at 4:19 pm
    WHen I build an image in Encore and then try to burn it with Nero, Nero tellsme it needs a CD and not a DVD to burn it. My DVD size is about 100 Mo but I still want to burn it on a DVD to avoid compatibility issues. Any clue how to fix it ?
    THanks,
    salvazalvi
    Roadkill replied 21 years, 2 months ago 3 Members · 3 Replies
  • David Garrett
    June 15, 2005 at 4:50 pm
    have you told Nero that you are compiling a DVD?? and that the burn choices screen is not showing the choice of CD??, if it is then click the arrow and then select DVD as your destination media.
  • Salvazalvi
    June 15, 2005 at 8:02 pm
    Of course, that’s my problem !!!
  • Roadkill
    June 15, 2005 at 8:47 pm
    If possible, the best solution would be to burn directly with Encore. If you want to burn with Nero and you want to avoid compatibility problems, I would suggest to add some kind of “dummy” DVD-ROM content to your project so that the total size is at least 1GB before creating the disc image file. Quite a few set top players will reject a DVD that has less data on it.
