Activity › Forums › AJA Video Systems › Building a FCP/Aja IO HD Workstation
John Crane replied 14 years, 5 months ago 7 Members · 17 Replies
Gary Adcock
December 2, 2007 at 12:06 pm[Jerry Hofmann] “The MXO can be calibrated exactly to match on a 23″ CD what I’d see on a CRT with a blue only gun. However the blacks are typical LCD black… (not quite there)”
While that may work for people not broadcasting their work, but not for my clients, and most standards approvals will fail materials monitored in this manner.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Jerry Hofmann
December 2, 2007 at 1:27 pmI’d venture to guess there’s more work for non broadcast than broadcast… but that said, if you watch the scopes, and use the MXO’s output, you’re certainly going to be within broadcast safe, and very close to what you’d see if you were using a calibrated broadcast monitor for the work.
I’d agree that there are better solutions, however the cost differential is pretty large.. JVC’s line of LCD’s are looking good for sure… but they start at about 3500… Cripes they quit making CRT’s too soon IMHO. Add an MXO at the lower end of things and you’re over 5k for a monitoring solution. The Io HD would add another 2500 to the solution.
Best of course would cost a lot more than that, but hey, I’ve used the MXO with a 23″ CD as have many others for broadcast work, and I’ve not had anybody send back the master because it didn’t pass…
Shane’s review of the MXO is pretty much what I experience with it. If you don’t see a difference side by side with a calibrated monitor, I think there is no difference. Other than those blacks not being really really black. I watched scopes for that measurement. It’s certainly better than naught. It does a fine job showing interlaced video on an Apple LCD too.
Jerry
Jerry Hofmann
December 2, 2007 at 1:54 pmI don’t totally dissagree with you Gary… I think though there is a place for the MXO…
I have an Io HD coming my way and will use it for the finish with a broadcast SD CRT, and the JVC LCD for HD work. Wanna see the blacks…
Hue and saturation and brightness sure look the same to me though.
Jerry
Shane Ross
December 2, 2007 at 8:28 pm[gary adcock] “Not to mention that there is not a way to properly monitor an interlaced signal on a progressive TFT display.”
Please remind me to demo the MXO for you the next time we see each other. Or just go to the Matrox booth ans ask to see it in action. The MXO can MOST DEFINATELY show you interlacing on the LCD…BOTH fields.
Gary…you have the same attitude I had when I was told about this. I didn’t believe it…I thought there was NO WAY you could get that image on a computer monitor. And I told this to the Matrox guy. SO he sent me one. And, as I stated in the article, I compared the image on the ACD to that of my PVM-14L5 and I’ll be darned if it wasn’t NEARLY identical. Nearly because the black levels of an LCD…ANY HD LCD, cannot compare to that of an HD CRT. But I’ll wager that this setup could stand up against the image quality you’d get on the other $4k range LCDs..
But we have thoroughly hijacked this thread with this topic…
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Gary Adcock
December 2, 2007 at 11:43 pm[Jerry Hofmann] “f you don’t see a difference side by side with a calibrated monitor, I think there is no difference. Other than those blacks not being really really black.”
However jerry judging black and white are part of the process, if the black level is not correct, the images will not pass standards guidelines.
gary adcock
Studio37
Jerry Hofmann
December 3, 2007 at 2:06 amBut gammas are alright, and checking scopes would keep you legal, right?
Jerry
John Crane
April 17, 2012 at 8:29 pmFCP X 10.0.4 & AJA Driver v.10.3 External Monitoring Success At Last!?
If you are interested in finding a solution to external monitoring with FCP X as I have been determined to do; AJA and Apple has finally come up with a solution – or so it appears at first install. The two new latest releases from Apple FCP X 10.0.4 and AJA Driver v.10.3 seem to be a winning combination – but then I have only had it on my tower for about two hours, but so far so good. If it remains stable I will be very happy. So put me down as optimistically cautious.
Just 10 days ago I was completely frustrated with external monitoring via AJA LHi for FCP X – it was killing me – as I was unable to reliably playback my shows on my broadcast monitor for my clients. In fact, I had to use my desktop monitor to play a recent cut for my client while the big screen sat dark because during playback the video would stall and the audio would inexplicitly drop out – horrifying to me and unnerving to clients – completely unacceptable by any professional standard.
After months of work around and beta solutions, I was determined to solve the external monitoring problem – once and for all – even if I had to buy a new solution from Blackmagic, Matrox or other. Or make the move to Premiere and/or AVID as so many colleague have done. But I actually love some of the new FCP X features. Specifically I think the magnetic timeline is huge improvement and I really love the background transcoding that saves me tons of time. The event browser also allows you to work visually – but those advantages will be discussed in a different article or blog.
On April 4, I called AJA tech support and discussed the problems I was experiencing. They were awesome and provided me with detailed instructions for a process that would delete Kona, QuickTime’s, and FCP preferences; reset the PRAM and then reinstall AJA drivers from their website. I was determined to do this immediately upon my return from a short trip.
When I returned from my trip, I set time aside to take on the task of re-configuring FCP and AJA – and to my immense pleasure Apple had an update 10.0.4 as did AJA 10.3 (released 4.10.12). This was a stroke of luck – but also a clear indication that both companies are determined to solve problems for their customers.
And best of all – it seems to be working…so I am cautiously optimistic…and have hopes that it will remain stable. Here is what I have learned and here’s what you need to know:
1) Use a dedicated boot drive for FCP X just as AJA recommends. I have FCP 7 with AJA LHi on one boot drive, and FCP X and AJA LHi on another – same AJA hardware – the difference is the software configuration.
2) Set Energy Saver to “Never” for Computer Sleep and Monitor Sleep. Go to Apple Icon (top left) > System Preferences > Energy Saver and move both sliders all the way to the right to “Never”.
3) Delete any and all existing KONA, FCP and QuickTime preferences.
· Delete KONA preferences
Go to Mac HD: /library/preferences/ and delete all the com.aja files
Go to Mac HD: /users/username/library/preferences and delete com.aja.KonaControlPanel.plist.
Go to Mac HD: /users/username/library/preferences and delete com.aja.Kona(your particular card/serial number)
Reboot
· Delete QuickTime preferences
Go to Mac HD: users/username/library/preferences/
Delete com.apple.quicktime.plugins.preferences.plist
Delete a file called: “quicktime preferences”
Reboot
· Delete FCP preferences
Quit FCP
Go to Mac HD: users/username/library/preferences/ and Delete com.apple.finalcutpro.plist: Drag the FCP user data folder to the desktop
Reboot
4) Install KONA LHi Driver Version 10.3 go to https://www.aja.com/en/support/kona/mac/kona-lhi/ and go to the software downloads section.
Try the first download; KONA LHi Driver Version 10.3, Control Panel,and Notes. but be forewarned that it may not work: This killed my Monitor; but AJA release notes clearly addresses this snafu – specifically:
After installing the AJA driver, if you experience any issues booting your computer, restart the computer while holding down the shift key (safe boot), uninstall the AJA driver and then install the NDD driver version instead.
The AJA NDD driver versions are the same as standard driver versions, but they remove the Macintosh Desktop Display feature.
So I “safe booted” (restart the computer while holding down the shift key for a safe boot – which eliminates all drivers except though essential to apple OS) my Tower, uninstall and reboot.
Then go back to AJA download and install the NDD Driver version instead. The version that you need is: KONA LHi NDD Driver Version 10.3https://www.aja.com/en/support/kona/mac/kona-lhi/, Control Panel, and Notes. Install and reboot.
5) Re-launch FCP, and it should work without much trouble. In fact, I was very pleased to find that automatically found the KONA card audio; and when I turned on my external monitor the video worked perfectly, too.
But if you don’t get that lucky go to: https://www.aja.com/pdf/FCP_X_and_AJA_10.3.pdf for instructions on “Working with Final Cut Pro X and AJA.”So far it appears to be very stable and I can actually jump around the timeline without the video freezing, or audio dropping out or FCP crashing – but let me know what you discover!
John Crane
Blogsjcf
