Bugs in vegas 8 and 8.0c
I have googled around but no one has a solution.
My problem is 2 fold.
1. When dealing with large MPEG2 files Vegas chops a lot of data out of it and this is then displayed as a large red or green area (on the timeline) where the missing data is. if there are many of these mpeg2 files, vegas will crash.
I got out of this by never using normal stream mpeg2 or VOB inside vegas, instead, I now use the Transport stream for MPEG2. I copy my mpeg2 direct from DVD using anydvd and VideoRedo.
2. The second problem arises when using the transport container mainly. When the audio of the mpeg2 is AC3, vegas gives this error (and closes):
Sony Vegas Pro 8.0
Version 8.0c (Build 260)
Exception 0xC0000005 (access violation) WRITE:0x5160000 IP:0x24A02BE1
In Module ‘mcdddec.dll’ at Address 0x24A00000 + 0x2BE1
Thread: Audio5Reader ID=0x850 Stack=0x485F000-0x4860000I have traced this dll as the main issue. It is the ac3 decoder. If I delete the dll from the folder, the wave will obviously not be used in the editor but the video loads just fine. Therefore this is a specific problem with AC3 especially when using the transport container for MPEG2. I did not get this issue with 8.0a (if I remember right)
I know people often say “well mpeg2 isn’t editing friendly”, but the transport method has been a big help and has eliminated all bugs I had. Now the main issue is AC3 decoder problems.
The only way I have been able to solve all issues is to use a transport stream mpeg2 and convert the ac3 to Mpeg audio using videoredo. But I have quite a few clips especially 5 HUGE mpeg2 files. (have a look here in HD mode> https://www.youtube.com/watch?v=hYWYuNti6Uo&fmt=22
Vegas does not like mpeg2 at all. Even Transport streams have issues at times with garbled frames. Someone needs to look at mpeg2 and ac3 in vegas because there are major issues here
Any help appreciated. Now to report a bug with videoredo…..
