Activity › Forums › Apple Final Cut Pro Legacy › Buggy Jittery spots for no reason?
  • Buggy Jittery spots for no reason?
    Posted by Vincent Strader on May 6, 2011 at 8:52 pm
    I looked at this thread
    https://forums.creativecow.net/readpost/8/1090539
    But this is dealing with something possibly even more basic. It’s not video I’m dealing with it’s just a still photo.
    Have you ever been key framing a simple photo for a slide show video, and that particular photo you’re keying just jitters for no reason?
    I’m creating a very simple animated scroll for a photo. Starting the scale out very small, and increasing the size over about 5 seconds so it looks like you’re zooming into the photo.
    In the middle of the zoom the picture will do a very noticeable blip, or jump, or something that’s causing me to want to rip FCP out and bash it on the ground if that were possible… sorry.. Italian temper.
    I haven’t trashed user data and prefs yet so that might be a fix to something. I’ve removed all attributes and started over. And the other times it will not blip in the exact same spot, but it will still jump a little in a different spot.
    Vinnie
    Message Signature:
    I don’t have any charming or witty things to put in my signature. So as Peter Griffen says, “That’s may mama!”
    Vincent Strader replied 15 years, 4 months ago 3 Members · 3 Replies
  • Michael Gissing
    May 6, 2011 at 11:33 pm
    Hi res stills can create aliasing as you move or zoom. A slight gaussian blur wil slightly soften which reduces jittery artifacts.
    Also have a look at Walter Biscardi’s tutorial on working with stills and how to understand pixels and dpi.
    https://library.creativecow.net/biscardi_walter/BCM-FCP-Tip-4/1
  • Steve Eisen
    May 7, 2011 at 12:39 am
    Make sure your keyframes are whole even numbers. Hi rez photos will jitter.
    Try Motion.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Vincent Strader
    May 9, 2011 at 4:11 pm
    Awesome info guys, thanks!
    Message Signature:
