Activity › Forums › DaVinci Resolve › Bug with imx mxf files?
  • Bug with imx mxf files?
    Posted by Andreas Knop on May 2, 2014 at 2:51 pm
    I’m using da vinci resolve 10 on windows 7.
    On the Media-Tab I click some folder to import media.
    Every time when the folder includes some sony-imx coded file with mxf-wrapper then da vinci searches and searches and…and finally also finds no other file codec (f.a. DNxHD).
    Every time the folder owns no sony-imx codec then everything works fine.
    Is this some strange bug or why doesn’t resolve simply ignore not readable files and only show the readable ones?
    Andreas Knop replied 12 years, 4 months ago 2 Members · 2 Replies
  • Rohit Gupta
    May 3, 2014 at 4:57 am
    Are you able to post a sample clip which would show the problem?
    Alternatively, send the clip to our support and ask them to forward to me.
  • Andreas Knop
    May 8, 2014 at 9:18 am
    Thanks for your help.
    unzip and look at following path:
    Test TON PCM/Avid MediaFiles/MXF/1/TESTUFPCV01.5368A84A.0058D0.mxf
    7456_testtonpcm.zip
