Activity › Forums › Blackmagic Design › Bug Report: Wrong Decklink DV-Settings ( PAL) in Premiere 2.0 ( only NTSC no PAL Compressor)
  • Bug Report: Wrong Decklink DV-Settings ( PAL) in Premiere 2.0 ( only NTSC no PAL Compressor)
    Posted by Oliver Petz on March 2, 2006 at 3:30 pm
    Hello
    Because 8 bit Decklink-Files are not working with After Effects Pro 7.0 i tried to work with DV-compressed
    files in premiere Pro 2.0 , but if you create a new PAL-DV-Decklink Projekt in Premiere Pro 2.0 and look to the Projekt Settings, there is always a “NTSC-Compressor” in the Video-Render and Premiere shows “Decklink NTSC DV Mode”.
    In Premiere Pro 1.5 everything is fine
    Sorry for my horrible english…
    Oli
    Oliver Petz replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
