Activity › Forums › Adobe Premiere Pro › Bug importing Final Cut XML from Redcine-X ?
  • Bug importing Final Cut XML from Redcine-X ?
    Posted by Angelo Lorenzo on July 10, 2012 at 6:21 am
    If I do a basic sequence edit in Redcine-x, go to File -> Export (shallow) and select FCP XML, and then import the resulting file into Premiere… everything appears fine except every clip in the timeline imports with a scale width/height of 0 under Effects Control > Motion.
    The XML file appears fine, it displays the height and width as follows (karats removed for proper display):
    38402160
    Anyone have any thoughts? I get the same result in CS5.5 and CS6.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
    Joe Tornatore replied 14 years, 2 months ago 2 Members · 1 Reply
  • Joe Tornatore
    July 14, 2012 at 11:22 pm
    I have had a similiar issue when importing XML from RedCine into Premiere. The sequence loads, the clips are where they should be and the 5k files are brought into the project…except the clips in the sequence don’t play. It’s just all black. Thing is I can double click on each clip in the sequence and it will load properly in the source window and I can even drop it from there into the sequence and it will play fine, but for some reason right off the bat after importing the video doesn’t appear in the program window. Any suggestions???
