Activity Forums Adobe After Effects BuckTv Particle Effect Help
  • BuckTv Particle Effect Help
    Posted by Evan Seitz on March 18, 2010 at 4:44 pm
    How can I achieve this particle effect?? (The small flurries floating around)
    https://www.buck.tv/work/sundance/begin-again
    I have Trapcode 2 and CC Particle World.
    Any help would be greatly appreciated!!
    (Also, my post on the Active Storage message board has had no success, mainly because the board is dead… Does anyone know why my 500 GB WD Hard drive might be getting dark purplish burn marks up and down the front and sides of it??? And is this a warning sign that it could lose everything or is it simply cosmetic????)
    ~Evan
    Jeremy Fabiano replied 16 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Fabiano
    March 21, 2010 at 11:24 pm
    The particles look like the snow plugin with a big blur filter of some sort..
    as for your HD yeah that’d scare the crap out of me. Sounds like it’s massively overheating – in your position, I’d offload everything off of that asap and scrap it. Just me though..
    -Jeremy
    If you didn’t supply enough information I will start making assumptions. I’m usually wrong when I assume.
