Activity › Forums › Zaxwerks › Bubbles
  • Bubbles
    Posted by Ken Bradburd on March 30, 2006 at 5:10 am
    Hello
    Does anybody have a good formula to make a soap bubble effect? I am using the 3D Invigorator (not Pro).
    Client wants the product label to be reflected in bubbles. (Product = soap).
    I am muddling through this and thought I should ask around. None of my attempts have been 100% satisfying. One thing I am wondering is if there is a way to get a “Wet Look”.
    By the way the PDF manual says that to make a Sphere, use a small dot with the Edge Profile called Semicircle. However, as far as I can tell, there is no Semicircle edge profile. I’m using the Half Pipe edge profile.
    Thanks.
    Ken Bradburd replied 20 years, 6 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    March 30, 2006 at 2:21 pm
    Hi Lumpy,
    Halfpipe is correct. To make the bubble look real you’ll want to use a reflection map which includes your product.. you’ll probably want to add some fake reflective elements.. You’ll also want to play with the highlight settings.
    Jon
  • Ken Bradburd
    March 30, 2006 at 5:43 pm
    Thanks Jon
    I ended up doing this with a different plug-in (particle generator set on low production). In Invigorator I wasn’t able to easily strike the right balance between transparency, reflectiveness, and readability. I realized that the true 3D aspect to the Invigorator was not crucial to my project. I am generating particles with a custom particle instead.
    I love the 3D Invigorator, it’s totally awesome. But I don’t get a chance to use it that often, so when I need to use it, it’s too deep and I struggle with it.
    I think I will sit down and do some wood-shedding with the Invigorator, in the future.
    Thanks Jon and thanks Creative Cow.
