Activity › Forums › Adobe Photoshop › Brush to Path
  • David Cabestany
    February 5, 2011 at 6:57 am
    Paint a simple instance of the path, as big as you can, do this by clicking once. Then command click on its layer thumb to select its transparency, then go to the paths palette and from the side menu select create path, try different values for the tolerance and finally finesse the path on illustrator.
    This will only work with hard edged brushes, tough.
