Activity › Forums › Apple Final Cut Pro › Browser tabs like Name, Notes, Reel won’t keep position. Normal?
  • Browser tabs like Name, Notes, Reel won’t keep position. Normal?
    Posted by Fabrizio D’agnano on September 21, 2017 at 1:36 pm
    Hello.
    I like to change the order of the browser tabs while editing, because I like the notes to show next to the clip name, and the reel, which I trick to show if a clip has already been used in another episode of the same series in the library, next to it.
    Now, sometimes the browser will keep those things in the same position they were in my previous session, sometimes it won’t, and will go back to the factory setup, with Reel not even showing (I have to add it again).
    Is this a common behaviour, or am I doing something wrong?
    Thank you!
    Fabrizio D’Agnano
    Rome, Italy
    Fabrizio D\’Agnano
    Rome, Italy
    Fabrizio D’agnano replied 9 years ago 2 Members · 2 Replies
  • Oliver Peters
    September 21, 2017 at 2:04 pm
    Seems to be common behavior and I would deem it a bug.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Fabrizio D’agnano
    September 21, 2017 at 3:51 pm
    Thank you Oliver.
    Fabrizio
    Fabrizio D\’Agnano
    Rome, Italy
